Applies to Pega Platform versions 7.2.1 through present.
This document explains what user-defined functions (UDFs) are. The sections on troubleshooting UDF issues pertain primarily to Oracle. If you are using another Pega Platform release or database other than Oracle, find the sections that explain user-defined functions (UDFs) in your deployment guide, either the installation guide or the update guide.
Forcing Oracle to revalidate UDFs
Before opening a Support Request: Must Gather information
Verifying UDF installation
To verify if the UDFs are installed and valid, run the following query, replacing RULES with your schema name.
While there are three (3) UDFs, there are 15+ Java classes that provide the implementation of the functions. This query checks for Java objects owned by the rules schema.
The schema name must to be in all uppercase letters.
select dbms_java.longname(Object_Name), status from dba_objects where owner= 'RULES' and object_type like 'JAVA%';
com/pega/pegarules/data/udf/directstreamreader/BasicEnvironmentAdapter VALID
com/pega/pegarules/data/udf/directstreamreader/CachedDirectStream VALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReader VALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase$Version6 VALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase$Version7 VALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase VALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2LUW INVALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2ZOS INVALID
com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderPostgreSQL INVALID
com/pega/pegarules/data/udf/directstreamreader/FixedCacheMap VALID
com/pega/pegarules/data/udf/directstreamreader/UnsupportedFeatureException VALID
com/pega/pegarules/data/internal/clipboard/directstream/BadReferenceException VALID
com/pega/pegarules/data/internal/clipboard/directstream/BadStreamDataException VALID
com/pega/pegarules/data/internal/clipboard/directstream/ByteArrayUtil VALID
com/pega/pegarules/data/internal/clipboard/directstream/DirectStream VALID
com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamEnvironmentAdapter VALID
com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamV7 VALID
com/pega/pegarules/data/internal/clipboard/directstream/InflaterV7 VALID
com/pega/pegarules/data/internal/clipboard/directstream/PropertyReferenceUtilities VALID
com/pega/pegarules/data/internal/clipboard/directstream/ReferenceString VALID
From this query you can see that there are twenty (20) Java classes installed in the rules schema in this environment. Seventeen (17) are valid; three (3) are not valid. The three Java classes that are invalid, indicated by their names, are not applicable to an Oracle installation and can be ignored.
However, if your query returns different results, you might need to take action:
- If your query does not return 15+ Java classes (the number varies depending on the Pega Platform version), then you need to follow the instructions for Installing UDFs after Pega installation or upgrade
- If the UDFs are installed but more than the three (3) Java classes for other databases are invalid, then you need to follow the procedure, Validating invalid UDFs.
Follow this procedure to validate the invalid Java classes detected during Verifying UDF installation.
Retrieve a list of installed, invalid UDFs
Test Oracle auto-validation on first-time use
- Connect as the schema user because the command you run in the next step queries against user_objects.
- Run the following command to retrieve a list of UDFs that are installed but not valid.
Select Dbms_Java.Longname(Object_Name) From User_Objects Where Status!='VALID' AND object_type LIKE 'JAVA%';
Examine the results, which may vary.
This example result set shows all of the Pega Platform UDFs in the RULES schema as invalid.
Sometimes, when the Java classes are installed, they may be in an invalid state. The first time that you use them, Oracle validates them, and there is nothing more that you need to do.
Follow these steps to use the UDFs for the first time to see if Oracle automatically validates them. These queries can be used on any database to test the UDF functions.
Test queries
- Replace vXYrules with the name of your rules schema and run this command:
SELECT vXYrules.pr_read_from_stream('pzInsKey', pzInsKey, pzPVStream) as "StringValue", vXYrules.pr_read_int_from_stream('pzRuleSetVersionMajor', pzInsKey, pzPVStream) as "IntegerValue", vXYrules.pr_read_decimal_from_stream('pzRuleSetVersionMinor', pzInsKey, pzPVStream) as "DecimalValue" from vXYrules.pr4_rule where pxInsID like '%CANNOT%'; - Replace
vXYdata with the name of your data schema and run this command:
SELECT vXYdata.pr_read_from_stream('pzInsKey', pzInsKey, pzPVStream) as "StringValue", vXYdata.pr_read_int_from_stream('pzRuleSetVersionMajor', pzInsKey, pzPVStream) as "IntegerValue", vXYdata.pr_read_decimal_from_stream('pzRuleSetVersionMinor', pzInsKey, pzPVStream) as "DecimalValue" from vXYdata.pr_data_admin; - Examine the results of each query to look for an error.
In any case, you are not interested in the results of the query but in whether the query throws an error.
- If the query fails with an ORA-29541 error, proceed to Forcing Oracle to Revalidate UDFs.
- If the query is successful, then run the command in Step 2 of Retrieve a list of installed, invalid UDFs again to see if the Java classes are now in a valid state.
- If the only invalid Java classes are the ones associated with non-Oracle databases, then you are finished with validating invalid Java classes used by the UDFs. See the Example.
- If the query results are successful, but the Java classes still show as invalid, proceed to Forcing Oracle to Revalidate UDFs.
Example
SQL> connect vXYdata/vXYdata
Connected.
SQL> Select Dbms_Java.Longname(Object_Name) From User_Objects Where Status!='VAL
DBMS_JAVA.LONGNAME(OBJECT_NAME)
SQL> connect vXYrules/vXYrules
Connected.
To force Oracle to validate invalid Java classes, run the following command for each Java class that is in an invalid state.
As before, replace vXYRULES in this example command with the name of your schema.
ALTER JAVA CLASS
"com/pega/pegarules/data/internal/clipboard/directstream/ByteArrayUtil"
RESOLVER ((*vXYRULES)(* public))
RESOLVE;
The ResolveUDF.sql script has the commands to resolve all of the Java classes in Pega Platform.
In earlier versions of Pega Platform, not all of these Java classes are applicable.
Consider the following choices for working with the ResolveUDF.sql script:
- Run the script, replacing vXYRULES with your schema name: The UDFs that are not applicable simply return an error.
- Run the script for the UDFs that show as invalid in your environment.
After you run the RESOLVER command for each UDF, you can rerun the following command to make sure that all UDFs are now valid:
If you have tried to resolve all of the Java classes listed above and there are some classes that still do not resolve, you should follow the instructions to drop the UDFs and reinstall them. See Installing UDFs after Pega installation or upgrade.
ResolveUDF SQL script
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/ByteArrayUtil"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/BadReferenceException"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/BadStreamDataException"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/DirectStream"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamEnvironmentAdapter"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/InflaterV7"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/PropertyReferenceUtilities"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/BasicEnvironmentAdapter"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/CachedDirectStream"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/DirectStreamReader"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/FixedCacheMap"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/UnsupportedFeatureException"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamV7"
RESOLVE;
ALTER JAVA CLASS "com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase$Version7"
RESOLVE;
RESOLVE;
RESOLVE;
Resolving UDF errors
If the UDFs are not installed or have been in some way corrupted, you see the issue in the following ways and can resolve it using the appropriate procedure.
Symptom or Error |
Explanation |
Action to Take |
ORA-29541 or |
Cannot resolve the UDF function Cannot find the UDF that is being queried |
When the UDFs are used and the data shown in the report is almost correct, but has some minor issues like extra spaces or spelling errors |
UDFs are found but, especially when the UDFs are installed in another schema and migrated to a new schema using database specific tools, they can become corrupted. If the UDFs are corrupted, you must reinstall them. |
ORA-04043 error |
Rather than being unresolved Java classes, the necessary Java classes are not even in the database. |
If you have followed the instructions to drop and reinstall the UDFs and are still seeing an issue, you need to create a Support Request (SR).
Before submitting your SR, gather the following artifacts to attach to it:
- The file setupDatabase.properties from the run, located in the directory <Pega 7.x Media>/scripts
- The log from executing the generateudf script, which is the file <Pega 7.x Media>/scripts/logs/PRPC_DatabaseLibraryLoader-*.log
- Screenshots of the output from the queries you have run in the section Test queries.
Related Content
When to use — and when not to use — unoptimized properties in reports
Missing columns in Explore Data
Optimize a property from the user interface
