Prerequisite
Before you begin using this patch release information, see the information for the minor release, Pega Platform 8.8 Installation and Update Information.
Release Notes for Pega Platform 8.8.2
See Platform 8.8 release notes, Starting with Pega Platform version 8.8.2, there are no Release Notes for patch releases. The Resolved Issues serve as your guide to changes.
Resolved Issues for Pega Platform 8.8.2
Resolved Issues – Client-reported issues that were fixed can be viewed by Capability.
If you think that your support case (INC) generated a Resolved Issue, specify the INC ID in the Pega Support Center Search field to find the Pega Platform 8.8.2 Support Document. Then use your browser’s or menu option to find the specific Resolved Issue in the Support Document. (Pega engineers can also search on the Issue ID, a Pega-internal work object.)
Pega Platform 8.8.2 Resolved Issues PDF - All the client-reported Resolved Issues for this release are aggregated in one document. When you click this link, the PDF page opens immediately. (You see a link to the PDF at the bottom of the Resolved Issues Support Document under File Attachments.)
Pega Platform changes with update impact - Resolved Issues that require the client to take some action, for example, change a setting, restart the system, and so on.
See also Issues Resolved with Update Impact.
Resolved Issues is different from the Pega Platform changes with update impact and Issues Resolved with Update Impact.
For more information about the client-reported Resolved Issues, see How to Get Support > Support self-service offerings > Resolved Issues.
Updates and Patches
See Pega Platform 8.8 Installation and Update Information, the aerial view table, the link to Install and Update.
@MaryCarbonara
Hi MaryCarbonara greetings,
We are planning to up upgrade PEGA ENV from 8.3.0 to 8.8.2. Is it possible for you to share the "Pega Platform 8.8.2 Installation and Update" document.
At present we are in configuration:
OS- Red Hat Enterprise Linux release 8.4 (Ootpa)
PEGA- PEGA 8.3
Application Server- WAS Proprietary information hidden
Data Base- Oracle19C
Thanks & Regards,
Ashish
