Case Management
8.1.8 Patch Resolved Issues for Case Management
Ticket # | Issue # | Title | Description | Product Area |
SR-D47146 | 515647 | Pick Values modal updated for deprecated list view handling | Pick values were not displaying in the menus below Case Management-> Tools -> My Work, including "Work entered by me", "Work by workbasket", and "Work resolved by me recently". This was due to the use of deprecated list views: the pick values modal was failing to show and hide the busy indicator because the indicator now uses jQuery, but list view does not include jQuery. In order to resolve this, the equivalent Report Definition pyEnteredByMe has now been added under the navigation rule : pzProcessAndCaseRulesMainMenu. | Case Management |
SR-D59504 | 524641 | Attachment drag drop searches only current Ajax context | When the Interaction for customer service was open and more than 1 task from the sidebar was open, the drag and drop zone was missing on any subsequent Task/Cases past the first. In an Ajax container scenario, getElementByID js was searching in all the containers because they were present in DOM, and it was losing context. To resolve this, the code has been updated to only search in the current context when using an Ajax container. | Case Management |
SR-D76291 | 547842 | Updated retry logic for S3 AddAttachmentFromEmail | When using the AddAttachmentFromEmail activity with S3 repositories, performing an obj-save on the data-workattach-file page executes a deferred save while also saving the file into the repository. if the data was inserted into S3 successfully but encountered an issue when saving the related data-work-attach-file page, the system was trying to call the save operation again. This tried to insert the duplicate attachment again to S3, causing an error on that side of the process. To resolve this, the duplicate Obj-Save functionality in AddAttachmentFromMail Activity has been removed. | Case Management |
SR-D80120 | 544216 | Custom attachment category parameter passed to dropdown | Attempting to use the out-of-the-box “Attachments control” which was configured at design time to use a custom category where both the custom category and the section class were in the same work class resulted in the attachment category dropdown defaulting to “File” instead of the custom category. Investigation showed that the custom attachment category name configured on the control was missing in one of the pre-processing activities sequence. To resolve this, the activity Work-.pzInitAttachContent and the initAttachmentPage activity have been updated to pass the custom attachment category parameter. |
Case Management |
Cloud Services
There were no 8.1.8 Resolved Issues for Cloud Services
Conversational Channels
There were no 8.1.8 Resolved Issues for Conversational Channels
Data Integration
8.1.8 Resolved Issues for Data Integration
SR-D38318 | 519715 | Data pages explicitly cleared after QP use | The Util Node was showing as Offline in the Search Landing Page, and when Jobs were submitted for execution from other Nodes the message "Detected active run with unreachable nodes" was logged. The util node, configured as a backgroundprocessing node, was running QPs; the queue size for custom QPs is 500 messages /queue items per minute, but investigation showed the requestor level and thread level data pages corresponding to the QP activities were not being cleared after use. This led to high heap memory issues that made the node unreachable, and has been resolved by adding code to explicitly remove the data pages when processing has finished. | Data Integration |
SR-D48369 | 514307 | Reinitializing Full Text Search will shut down Elastic Search regardless of search initialization status | Pega search was only sporadically working after converting from standard sandbox-marketing to largesandbox-marketing. This was traced to the Full-Text Search initialization having failed on the app-tier node during re-initialization. As part of re-initialization, the existing node is shut down and the Elastic Search node is started. The shutdown process relied on a boolean flag which indicated if the current status of full-text search initialization was successful. In this case, ES was trying to validate all the cluster level settings, for every save of one of the cluster level settings, but could not due to topology changes in the Util Tier node. The boolean flag indicated initialization had failed so the shutdown process was not invoked, yet the system was attempting to start the second instance of an ES node on the same machine. To resolve this, the shutdown FTS code has been modified to shutdown ES regardless of the search initialization status. | Data Integration |
SR-D56293 | 536776 | Resolved timeout errors related to getIndexInfo | When attempting to import large files (around 300MB) via Designer Studio a time out error was seen, but the same upload worked as expected from the command line. Investigation showed that the "approximate" argument in getIndexInfo caused wasteful analytic operations to be run on the database, hampering performance. To resolve this, areas where the results of the analysis are not needed have been modified to have aApproximate set to be true so it will not be run. | Data Integration |
SR-D60375 | 527755 | Resolved upgrade SqlSyntaxErrorException | When trying to perform an in-place update, the error "SqlSyntaxErrorException" appeared. Investigation showed that DDL statements for Adding 'pzInsKey' as PrimaryKey for Tables pc_work and pr_sys_locks were generated during the upgrade while pzInsKey was already the PrimaryKey in corresponding tables. This has been corrected. | Data Integration |
SR-D60830 | 533028 | Logic update for classloading synchronization | The synchronization logic for classloading has been updated to resolve intermittent deadlocking seen when two DataFlow threads are executing a distribution test. | Data Integration |
SR-D61253 | 527654 | Exception stack trace will be included as comments in generated assembly code | When there is an exception during assembly time, that original exception message is assembled in the generated code. To improve the process of finding the the root cause by examining the original exception stack, the system has been updated to insert the original exception stack trace into the generated code as comments. | Data Integration |
SR-D62755 | 522827 | Enhanced diagnostic logging for Email Listener failures | In order to better diagnose issues where the email listener entered a disabled state as soon as it was started, a catch block has been added to enhance logging the reason of failure | Data Integration |
SR-D64558 | 527676 | AttachmentContent supports S3 storage | Using a D_AttachmentContent data page to display the contents of an attachment by way of the pyGetAttachmentContent activity worked when using the Pega database for storage, but generated an error stating CMIS access was disabled after switching to S3 storage. This was traced to restrictions on Link-Attachment pages in Step 2, Line 64 of pyGetAttachmentContent to enable attachment stream retrieval from web storage and repositories by D_AttachmentContent, which has now been removed. In addition, pyGetAttachmentContent has been updated to behave the same whether a Link-Attachment page or Data-WorkAttach page is provided when populateAttachStream is set to false, and the rule documentation (description/usage) has been updated accordingly. | Data Integration |
SR-D65112 | 541147 | Added support for imported rules to populate bixreportpage | Extract rules were not holding the filter criteria after upgrade while performing save-as (for the first time) of the imported rules from the previous version. Criteria were held when the filters were created in the new version. This was caused by BIX extracts created in earlier releases (7.x) not having bixreportpage included. When an environment was upgraded to 8.x versions, opening an extract required the bixreportpage to be populated with Report Definition metadata including the filters defined in the actual extract. Although the filters from the original extract were converted to filters that are acceptable by ReportDefinition, they were not being added to bixreportpage on opening the extract. To resolve this, the system has been updated to copy the filters back to bixreportpage on opening the extract in the upgraded environment. | Data Integration |
SR-D66986 | 539412 | BIX command line support improved | Post-upgrade, it was seen that changes to the engine which validate that Data-Admin-DB-Name is not defined multiple times caused the BIX command line extracts to no longer work the same way. In order to improve backwards compatibility, updates have been made to loosen the validation in JdbcConfigurationFactory to always prefer prconfig settings if there are multiple definitions. | Data Integration |
SR-D71669 | 540099 | Logic trimmed for better Listener performance | After multiple email listeners with Data indexing were enabled, the FTSIndexer queue was filling with Email Listener instances. Investigation showed that although Listener Management has logic for updating the last access time of all listeners by using APIs, the Email Listener was explicitly opening the email listener rule to update the last access time every time it was run. This has been corrected. | Data Integration |
SR-D71977 | 535600 | Obj-Browse will retrieve more than 50 records | After performing multiple skims, a newly added property was not retrieved when an Obj-Browse was performed. In Obj-Browse action, when a class is mapped to an external table and does not contain BLOB column pzpvstream, in a specific case where pxObjClass value is a reference to a parameter, a list of properties mapped to the class explicitly by querying pr4_rule_property table using NativeSQL is fetched. This call by default returns only 50 records: in cases where there are more than 50 properties for an external class, some of the properties from the obj-browse response mapping are therefore missed. To resolve this, the limit of 50 records has been removed from this NativeSQL call. | Data Integration |
SR-D75649 | 547565 | OrgChartWorkGroup update issue resolved | The instances of Index-PegaFS-Data-OrgChartWorkGroup table were corrupted after adding a new department via the landing page. This was traced to the missed scenario of a Page-Copy with declare index present in it, and has been resolved. | Data Integration |
SR-D76291 | 541013 | Check added for Repositories before saving attachment | When creating or updating a case through email listener, the Link-Attachment defaulted the pxStorageType to 'WebStorage'. This caused an issue when using PegaS3, which needs pxStorageType 'Repository'. To resolve this, a check has been added to see if Repositories are enabled, and if they are the storageType will be set accordingly. | Data Integration |
SR-D79565 | 541532 | BIX extracts traverse up from embedded pages to find target tables | For BIX Extracts with Output Format : Database Schema, the target table name was not being generated if the properties were buried under two levels of Embedded Pages. Instead, in case of multiple nested levels of PAGE property types, the system ended up referring the immediate Parent page or its parent PAGE for pySourceName. Since this is of type PAGE, an empty value was returned for the target table name and the extract would fail. To resolve this, the system has been updated to traverse up the node parents until the correct target table name is found. | Data Integration |
SR-D84880 | 546890 | Null check added to resolve addmapcasetomap error | Using a createcase flow shape to create child cases by looping on a page list on the parent case resulted in pzaddmapcasetomap throwing an exception related to the activity pzLoadCaseHierarchyWrapper in step 5. This was traced to a page being removed after the list of pages was received in findPageByHandle, and has been resolved by adding a null check. | Data Integration |
Decision Management
8.1.8 Resolved Issues for Decision Management
SR-D37421 | 514593 | Cross-site scripting security added to Marketing Offers | Cross-site scripting protections have been added to Marketing Offers, which had a potential vulnerability when using Firefox. | Decision Management |
SR-D45608 | 519902 | Correct service instance name passed for data flow in DSMStatus | When using the Connect-HTTP service "DSMStatus" to provide the node and status information as seen on the various tabs of the Designer Studio > Decisioning > Infrastructure > Services landing page, using DataFlow as the service parameter for the HTTP service method resulted in an empty response when the expectation was to get the information regarding the cluster details of Dataflow node type. This was traced to the service instance name not being parsed correctly when used for Data Flow services, and has been resolved by ensuring the correct service instance name is passed for this use. | Decision Management |
SR-D47618 | 516300 | Statistic rounding error in ADMSnapshot Agent with Oracle corrected | While running the ADMSnapshot Agent, the exception "internal.mgmt.Executable) ERROR com.pega.decision.adm.client.ADMException: Failed to complete ADM Data Mart snapshot" was seen. This was traced to an issue with the rounding of performance statistics when using Oracle, and has been resolved. | Decision Management |
SR-D54218 | 518599 | Deadlock in static Initialization of IntList resolved | JVM Deadlock was seen related to the static Initialization of a subclass field in class com.pega.decision.strategy.ssa.runtime.collections.api.IntList . Thread dumps showed threads in RUNNABLE State that were parked to wait for class initialization, and this was traced to a missed sonar alert which failed in multi-threading. To resolve this, the system handling has been updated to prevent potential deadlock. | Decision Management |
SR-D60268 | 521460 | Performance and thread-handling improvements for SSA | The SecureRandom class was used internally by SSAExecutionContext indirectly via UUID generation. Because this exhibited performance issues on some Linux environments, UUID has been replaced with static AtomicLong. In addition, a memory leak was observed when the strategy (SSA) execution resulted in an exception, and the strategy template has been modified to gracefully shutdown the VM under all circumstances. Thread-safety measures have also been tuned to be more fine-grained to reduce the potential thread contention that was seen while borrowing the SSAInterpreter object from SSAInterpreterPool. | Decision Management |
SR-D68558 | 536676 | Timing updated for Cassandra session change thread lock | An issue with unresponsive nodes was traced to the method used for notifications about Cassandra session changes. A thread trying to obtain a Cassandra session acquired a read lock, then if it then determined that a new session had to be created it would also acquire a write lock, preventing other nodes from trying to acquire the session. After creating a session, the thread notified all session change listeners while holding the write lock, causing deadlock with dependent services. To resolve this, the timing has been updated by moving the session change notification to the listeners outside of the section guarded by the lock. | Decision Management |
SR-D85095 | 546340 | Updated COUNT logic for strategies with ssavm set to true | An error was seen when attempting to save a strategy after setting ssavm to true, indicating an issue in the “COUNT” method in Group By shape. Since the source field is not used and does not need to be evaluated here, the system has been updated to ignore the source field if the operation is COUNT. | Decision Management |
8.1.8 Resolved Issues for Low-Code Application Development
SR-D44942 | 518353 | Guided tour popups handling added for right-to-left language locales | Guided Tour Popups were still appearing in the default EN location after switching to the ar_AR locale. This was traced to a missed use case for locales using a right-to-left mode such as Arabic or Hebrew, and has been resolved by updating the guided tour engine openPopOver function to account for the HTML tag dir attribute for value of "rtl". This will anchor the pop over to rightBottom / and display the arrow on the rightTop instead of leftBottom / leftTop. | Low-code app development |
SR-D54963 | 524113 | Updated Decision Table validation for multiple OR conditions | When the Decision Table had multiple OR conditions, the table was verified as consistent even when two rows had the same value. Analysis showed that when Show Conflicts encountered multiple 'or' conditions in a row that matched the same conditions in other rows, it considered them to be different rows. This has been corrected. | Low-code app development |
SR-D54984 | 529208 | Resolved ruleset save issue for Google Chrome/IE | When using particular versions of Google Chrome or IE, the intermittent error "pyComponentInterfaceClass: <user> does not exist or is not a valid entry for this ruleset and its prerequisites" appeared when attempting to validate an application, and the ruleset could not be saved. This was traced to changes made in the browser around password handling, and has been resolved by explicitly clearing out the pyComponentInterfaceClass if that value is not in use. | Low-code app development |
SR-D70447 | 533598 | SQL injection protection added to Circumstanced Search | Parameters used by the PegaAccel-Task-CircumstanceSearch.pzGetCircumstancePropValues activity are now encoded to prevent SQL injection attacks. | Low-code app development |
SR-D72672 | 536387 | Security updated for CreateOperator | In order to improve security, CreateOperator in Pega-ProCom will require authentication to run with pxCanManageUsers privilege. | Low-code app development |
SR-D75469 | 538120 | Resolved null-pointer exception in Expression Builder launch from activity rule | A NullPointerException occurred in SafeURL when trying to launch the Expression Builder from an activity rule. This was trasced to a failure to get a value property in a target field due to the target element and its parent element containing the same value for name attribute. This caused the parent element to be considered instead of the target element. To resolve this, the search for the target element in parent tag will use '$p' along with 'target element name' in query selector. | Low-code app development |
SR-D79266 | 544531 | pyStatusWork for parent case correctly resolved | pyStatusWork was not getting updated for the parent case even though the case passed through the resolution stage. This was an unintended side effect of work done regarding resolving a subcase if it was opened from the review harness, and has been resolved by updating the findPageByHandle activity to return the correct page when there are multiple pages with the same key. | Low-code app development |
SR-D87673 | 548628 | PegaCESvcsIntegrator security updated | Security updates have been made which now require authentication to consume the services from the PegaCESvcsIntegrator package. | Low-code app development |
Mobile
8.1.8 Resolved Issues for Mobile
SR-D37275 | 519027 | Enabled PDF attachment for iPad Safari | It was not possible to select the PDF option when attempting to attach a file while using iPad Safari. This has been corrected. | Mobile |
SR-D76134 | 542160 | "Offline" icon shows when simulating offline mode | When simulating offline mode by selecting "Settings->SystemInfo->Simulate Offline checkbox" and moving to MyWork, "Offline" did not appear in the header. This has been corrected. | Mobile |
Project Delivery
There were no 8.1.8 Resolved Issues for Project Delivery
Reporting
8.1.8 Resolved Issues for Reporting
SR-D53176 | 541793 | Error when adding function filter will persist | When an exception occurred while adding a filter in the report viewer, the error was shown but cleared due to an immediate refresh of the parent section. Analysis found that step2 of pzGetFiltersFromContent was failing, after which the error was shown, the section reload happened, and the error disappeared. To resolve the error being cleared prematurely, the pzOnLoadReloadReport control has been modified so that when there are messages on the top level page (pyReportContentPage), a parameter will be set on HarnessContextMgr to not to clear them during the next refresh call. | Reporting |
SR-D71408 | 534932 | DIrty check flag triggered by adding columns and filters | If a report was edited and closed without saving, the dirty check worked as expected. However, if new columns or filters were added and the report closed without saving, the dirty check did not appear. This has been resolved by updating the check logic. | Reporting |
SR-D76204 | 543591 | Index conflict resolution logic updated | After configuring a dedicated index on delivered Class - PegaCA-Interface-Contact, trying to generate the index resulted in an error indicating a type conflict in delivered classes/properties. This has been resolved by updating the conflict resolution logic. | Reporting |
Security
There were no 8.1.8 Resolved Issues for Security
System Administration
8.1.8 Resolved Issues for System Administration
SR-D37317 | 518893 | Run Ruleset Cleanup defaults to true | After upgrade, the rule categories and rules were not showing correctly in the App view of the Dev Portal. Many warning messages were also logged related to the Decisioning DM Sample application. This was traced to the rules cleanup script not running properly. While there was a workaround of applying the ruleset cleanup scripts manually after removing the queries that reference the pr_engineclasses table, the cleanup will now be set to run by default (run.ruleset.cleanup=true). In addition, the logic to determine which RuleSets to include has been simplified and most of the pr4_rule_vw deletions have been combined. | System Administration |
SR-D46681 | 514435 | SnapStart supports SAML2 Authentication | When using an HTTP Post to SnapStart into Pega using PRCustom style or PRAuth style SAML authentication, the login was looping back to the login request. Investigation showed that the Pega ACS was posting data properly back to the RelayState URL, however the login activity was not getting the SAMLResponse and simply sent a SAML Login Request again. This has been fixed by updating reqContextURI in case of SAML2 Authentication service so pyActivity=value will be passed. | System Administration |
SR-D48396 | 520424 | Hazelcast upgraded to resolve node startup issue | Post data upgrade, the ADM tier failed to start and the error "java.lang.IllegalStateException: Node failed to start!" appeared. This was traced to a dormant bug in Hazelcast 3.11 that caused starting nodes to fail when the Hazelcast master node was shutting down, which was exposed by recent Pega changes made to enable parallel restarts of nodes in Cloud environments. Hazelcast delivered a fix for the parallel restart problem and the hotfixed jar has been merged into the platform. | System Administration |
SR-D48762 | 518297 | Enhancement added to support DB2 CREATE OR REPLACE view syntax | After creating the product, attempting to import it on another environment failed due to incompatibilities with the syntax. In SQLGeneratorDb2.getViewSourceStatement(), when the View definition is fetched there is a check whether the view starts with "CREATE VIEW". Since the customer view of "CREATE OR REPLACE" was not supported in Db2LUW, it didn't match and appended the "CREATE VIEW" statement again. This happened only when using DB2, and has been resolved by updating the logic in SQLGeneratorDb2.getViewSourceStatement() to support CREATE OR REPLACE VIEW statements. | System Administration |
SR-D52249 | 515703 | Resolved Oracle thread deadlock for Merge SQL | After starting a large cluster and running it for a couple of days, Oracle Deadlocks started to appear due to resource contention during MERGE SQL execution on the PR_INDEX_REFERENCE database table. The "ORA-00060: deadlock detected while waiting for resource" ERROR occur continuously every 10 minutes during the "MasterForNewAgents" Daemon run. All JVMs are impacted by the ERROR/Deadlock. Investigation showed that even though the identified / problematic Data-Agent_queue instances were disabled for PegaAESRemote, the MERGE SQLs continued to fire. To resolve this, an update has been made so the system will skip the copy of rule reference property from RAQ, while creating DAQ. | System Administration |
SR-D53139 | 516511 | ExposeCols supports running serially | MSSQL can be prone to deadlocking, causing potential issues with ExposeCols (column population and index generation) which defaulted to multi-threaded. To resolve this, the system has been updated to allow configuration of ExposeCols to run serially: the properties expose.commitRate, expose.numOfThreads, and expose.batchsize in setupDatabase.xml ExposeCols executions, which were previously only available to prpcUtils, will be honored. | System Administration |
SR-D55160 | 520356 | Namibia and Botswana added to Currency Symbol values | Support has been added for the Namibia (en_NA) and Botswana (en_BW) locales in the default Currency Symbol values. | System Administration |
SR-D56527 | 538302 | DSS PegaAESREmote*ResetTableStats set to false | In order to prevent an issue with resetting table stats that potentially impacts postgres in an unintended fashion, the DSS PegaAESREmote*ResetTableStats has been set to false. | System Administration |
SR-D57038 SR-D83192 |
519381 545056 |
JobScheduler DST handling updated | When the locale being used changed out of Daylight Savings Time, scheduled jobs did run at the same local time as before but instead ran an hour earlier than expected. Investigation showed that jobscheduler calculated the next runtime based on the time difference from the cluster reference time and current time in milliseconds, and this offset in milliseconds was added to next run time. Since the cluster was started in DST, the job was running on same time due to the time difference. To resolve this, the system will use a calculation offset and set hours/minutes to nextRunTime object so that calendar lib handles daylight savings. | System Administration |
SR-D58927 | 522289 | Added expiration for orphaned tracers | After tracing a REST service, the tracer was persisting but not showing in the requestor list from Admin studio. The operator shown in the error did not have access to the system anymore, and other users were not able to trace the service rule. Trying to clear the requestors in all the nodes using API POST /nodes/{nodeID}/pools/requestor/clear also did not resolve the issue. To address this, a distributed rule watch expiration has been added. | System Administration |
SR-D61094 | 527341 | Browser cache disabled to ensure fresh RAP file retrieval | When using RAP download, reusing the same filename as a previous download caused the older file to be retrieved and not the newer version under that name. This was caused by RAP using the browser cache and downloading the same folder from service export directory. To resolve this, validation has been inserted to disable using the browser cache for the HTTP response. | System Administration |
SR-D63668 | 525479 | Access Control Policy updated to handle NotEqual with valuelist | When editing the Access Control Policy Condition rule in Designer Studio and setting condition to 'is not equal', comparing it to a list generated the error "function not found". The same configuration worked as expected for the 'is equal' condition. This has been resolved by updating policycondition to handle a not equal scenario combined with a valueList property. | System Administration |
SR-D74848 | 536998 | Updated key handling for ProcessJWT | After configuring an authentication service which used the ProcessJWT activity to validate the token received, the error "Unable to process the Json Web Token " was seen. Analysis showed the error was caused by a duplicate Key Id in JWK Endpoint Response: the system removed keys after processing, and in the case of duplicate keys the system was throwing null pointer exception because the key had already been removed. To resolve this, the system has been updated to not remove the keys from the map as part of this process. | System Administration |
SR-D76409 | 540299 | Cleanup added for staging directory | Temporary files from imports and exports (from DevOps) were filling up the staging area disk space because there was no automatic process for cleaning up these local files. This has been resolved by adding an enhancement that will clear the directory on Engine Startup and any time ParUtils.setStagingDirectory gets called to initialize the staging directory. | System Administration |
SR-D78987 | 544060 | Support for custom jvm.args added | In order to support Oracle PKI and other ticket based authentication, support has been added for custom jvm.args properties to setupDatabase and prpcUtils properties files. | System Administration |
SR-D79178 | 543311 | SameSite cookie setting added for Mashup support in Google Chrome v80+ | The Google Chrome browser version 80 and above now treats SameSite with a blank value as "Lax" by default, causing mashup scenarios to break. In order to compensate for this change, support has been added for setting SameSite=None in Cookie Settings; this value automatically includes the “secure” cookie flag, which enforces HTTPS for the Pega server and mashup. For mashups to work, SameSite should be set as None. Create a Dynamic system setting in the Pega-Engine RuleSet with the name “security/csrf/samesitecookieattributevalue” and the value "None" and restart the server. (The SameSite value "None" works only in secure HTTPS connections.) Note: The SameSite cookie may be set to None/Lax/Strict, based on the requirement. For cookie requirements other than mashup, it should be set as either Strict or Lax, depending upon your application. | System Administration |
User Experience
8.1.8 Resolved Issues for User Experience
SR-D34359 | 510602 | StretchTabsWidth performance improvements | Slowness was seen when a new intent task was created through an interaction. To improve performance, some of the unnecessary calls to the Layout Group _updateStretchTabsWidth() function have been eliminated, and the function code has been updated to use native javascript performant helper functions so it starts rendering sooner. A flag has also been added to disable addnewtab and resizeactions: these need to be enabled through pega.u.d.DISABLE_LG_RESIZE and pega.u.d.DISABLE_ADDNEWTAB. | User Experience |
SR-D43740 SR-D45101 |
512184 512530 |
Added support for Helper Text Question Mark with visibility condition | The Helper Text Question Mark was not displaying if the control was configured with "Help icon with overlay on hover" combined with a visibility condition. This was a missed use case, and the expression visibility support for controls.changes have now been added in the pzpega_ui_DLCellTemplate.js file. | User Experience |
SR-D45251 | 523815 | Harness context will be stored to handle on click executed outside of the Ajax Container | An exception was generated in the interaction portal on execution of a post-value action for the on-change event on a text-box in the service case: "Failed to find instance Work-Interaction-Research.EmailBodyRTE of type Rule-HTML-Section". This was traced to a condition where clicking outside of the Ajax Container context to trigger the change caused the Events code to execute the event in the active context when the active context had already been changed by clicking outside of the AC. To avoid this, the system will store the harness context in the event object using pega.ctxmgr.getContextByTarget(target) API. Additional changes were also made to handle the context switching in case of post value when the blur triggers a change in context. | User Experience |
SR-D45848 | 515525 | Added toggle to hold radio button value during multiple service case creation | When a field was implemented with a radio button control in the service case screen, starting two cases of the same or different case type (with the same property and control) resulted in the selected value not sticking in the first case when selections were made for the second case. This was traced to multiple radio buttons with the same name in the dom for different AJAX containers: as per radio buttons behavior, only one could be selected if they have the same name. To correct this issue, updates have been made to change the name on radio buttons which are inside the hidden AJAX container and toggle the changes when the buttons should be shown. | User Experience |
SR-D46451 | 511711 | Resolved signature capture transaction error | After configuring a launch modal in flow to capture a signature, trying the submit the flow after capture was resulting in the error "This action is not allowed as it is outside the current transaction." This was traced to the flow in the modal HTML which contained a hidden input for transaction ID, and this ID was not being updated. As this was part of a legacy area, the hidden input transactionID element in pzFlowDetails has been removed. | User Experience |
SR-D47344 | 519892 | Single quotes escaped in rich-text editor title field value | A JSON parse error was caused by single quotes not being escaped in the rich-text editor title field value. This has been corrected. | User Experience |
SR-D47689 | 520828 | EvaluateConditions properly sets context for refresh section | Rule Not Found and Unresolved Assembly Errors were seen in production logs after upgrade. Investigation showed that the method context used by pzpega_ui_changetracker.js in "evaluateConditionsOnXThread" was not reset correctly, causing the refresh section response for the Recents List to not be properly updated. This has been resolved by updating the evaluateConditionsOnXThread method to set the proper context after evaluateClientConditions is run. | User Experience |
SR-D49305 SR-D53488 |
519365 520015 |
Tab layout group handling improved | A difference in scrolling speeds between left and right arrows and an issue with the cursor correctly being redirected to mandatory fields were traced to errors in the tab layout group handling. The right scrolling issue was due to the calculation for right tab movement being incorrect in certain resolutions with relatively positioned elements, and has been corrected. The cursor redirect was caused by an error in the layoutgroup focus when used inside a screen flow where the first focus goes to the screenflow navigation on load, and has been resolved by adding a try catch for an invalid selector in case of a div error. | User Experience |
SR-D50469 | 519924 | Helper text fetches field value fr dropdown | A dropdown control configured with a helper text with a field value was not fetching the field value in runtime, but instead displayed the Field Value Name. This was traced to an issue with case sensitivity in getLocalizedValuecall in DLCellTemplate, adn has been resolved by updating pyToolTip to pyTooltip. | User Experience |
SR-D51555 | 516494 | Resolved system hang after changing input field value post note | After upgrade, a session was hanging in a Non-Member Search Phone interaction after navigating back from "Add or edit attachments" window. The same code worked as expected in the Member Search Phone interaction. Investigation showed that changed values (transaction ID, pzFromFrame) were being sent to the client twice, once in the popup window after attaching the note and again to the parent window. When the changed values were consumed and used in next actions, a mismatch resulted in pzFromFrame. To resolve this, the system has been updated so the Client will not consume the pxThread.pxClientExchange value if pxThread.pxClientFrame is different from what the current tracker is using. | User Experience |
SR-D51601 | 516703 | Hover logic updated | When using a dropdown in a grid layout configured with a smartInfo to be displayed on Hover, the smart tip was sometimes not displayed when the hover moved from the top to point to the dropdown. If the hover was done quickly, it was displayed. Previously, the hover was calculated only by cursor x, y positions and elements boundaries: to resolve this issue, the logic has been updated to also consider cases where the element is still hovered without meeting these conditions. | User Experience |
SR-D52144 | 515671 | When no active document is available on login, first document will be marked active | After logging into the user portal, attempting to perform operations like (opening a case/work object, opening reports etc.) caused the browser request to spin or freeze. The only way to recover was to close and re-launch the browser window/session and re-login. This issue occurred when there was an active reportdefinition document before the browser/node crash in the tabless dynamic container(DC) portal. After recovery, the dynamic container did not recreate the report definition document but instead tried to activate the first document in the portal, which in this case was the default harness configured in the Dynamic Container. As it was not yet loaded, exceptions were thrown. To resolve this, when no active document is available, the first document will be marked as the active document. | User Experience |
SR-D53757 | 523128 | JSON parsing error on export resolved by ensuring parameter encoding | Menu items like "PDF" and "Excel" were not loading on click of the "Export" Button, and an "Exception in parsing JSON" message was logged. The export worked as expected when the menu rule actions of each menu item were modified to remove the openurlinwindow actions. This was traced to the Response JSON being broken due to a invalid format created when the "propositionName" was passed as an unencoded parameter when the report was exported. This has been resolved by ensuring the input parameters are encoded before creating the URL. | User Experience |
SR-D54594 | 521633 | Enhancement added to customize the clearing of error messages when performing modal actions | Opening any modal dialog, for example adding a row in Table/Grid layout, cleared any existing validation error messages on UI screen. In order to make this behavior customizable, a flag has been introduced to control the clearing of error messages from primary pages on grid actions. Updates have been made in the ui_grid, ui_grid_dragdrop and ui_repeatlayout JS files to include this flag in activity parameters and the pzdoGridAction activity has been modified to consider the flag. | User Experience |
SR-D54785 | 524802 | Corrected grey area seen when dragging tabbed layout Smartinfo scroll | When using Show Smartinfo in a tabbed layout group, a grey area was seen in the harness while scrolling. Scrolling up so that Smartinfo was out of view port caused another scroll bar to seen: one scrollbar was attached to the workarea div and the other to the body, and the gray area issue was only reproducible when explicitly dragging the (second) scrollbar attached to the body. To resolve this, if the popup is below the viewport using Smartinfo and the height calculated is negative, then the popup's height will be set to 0px. | User Experience |
SR-D54920 | 518272 | Extra checks added for pasting Excel content to rich-text editor | Copying content from Excel into rich-text editor pasted an image of the content either instead of the actual content or in addition to the actual content. This was traced to the handling of the isHTML flag: the flag should be set to true when there is HTML content in the datatransfer item or while pasting images (!isHTML is the condition in if). However, the sequence of the data items in the datatransfer can change depending on the browser/OS, causing isHTML to sometimes not be set to true before it is used in the condition while pasting images. To resolve this, changes have been made to the pasteHandler in the pzpega_ckeditor_extras file so proper checks are made to figure out the type of data from the clipboard that is being pasted. | User Experience |
SR-D55294 | 517216 | Work List loads as expected in IE | After upgrade, the Work List was not loading in IE. This was an unintended side effect of work done to handle resizing the Recents list when another tab was open, and that change has been reverted to resolve this issue. | User Experience |
SR-D57610 | 518694 | Last X Days and Next X Days removed from displayTimePeriod | Last X Days and Next X Days removed from displayTimePeriod When the date filtering value of "Last X Days" was selected in a report definition, the error "An invalid comparison value or an invalid column has been entered for the right-hand side of a filter condition. Enter a valid column, calculation, or literal value" appeared if any value was entered other than the predefined (like last 8 days, last 31 days etc). This was traced to the control pzdisplayTimePeriod List view returning all field values (getFieldValues) under the class name "Embed-ReportingPeriod" with FieldName as "pySymbolName". This has been resolved by modifying pzdisplayTimePeriod to remove Last X Days and Next X Days. |
User Experience |
SR-D57928 | 526007 | Special characters in field value display as expected | After configuring a text input with a helper text (Help Icon with overlay on hover) that pointed to a Field Value, and the Field Value pointed to a property from the clipboard {.HelperText1} that had a value like (Some text here), in runtime the text in helper was printed with the HTML ASCII number and the text instead of the parentheses around the text. This has been resolved by escaping the special characters so they are displayed as expected. | User Experience |
SR-D58868 | 531798 | Check added for unicode calendar values | After creating a repeating grid section for work report definition with enabled filter option, running the section and giving the filter value in unicode calendar form such as 2019/11/12 did not pass validation. This has been resolved by adding a check for unicode values. | User Experience |
SR-D59003 | 522036 | Cross-site scripting security added to RWClasses | Cross-site scripting protections have been added to the RWClasses parameter. | User Experience |
SR-D60447 | 522751 | Corrected unexpected save warning when switching tabs | When using the Interaction Portal, entering case data on one open tab and then switching to another open tab caused the system to display a Save warning message as though the Tab has been closed instead of switched. This has been resolved by updating the system to skip the dirty alert when bPrompt is false in the Ajax Container container case. | User Experience |
SR-D61560 | 539472 | Support added for multiselect control with SmartTip for iPad | When using a multiselect list control to a lproperty with Smart Tip configured, choosing one item on an iPad and then trying to tap or drag down the vertical scrollbar caused all listed items to disappear. To resolve this, the multiselect control has been updated to handle the popover exit on smart popover hover along with arrow key navigation support for tablets. | User Experience |
SR-D62038 | 529156 | Multiselect control security improvements | Control_multiselect and multiselectresults have been modified to include protection against unauthorized javascript execution. | User Experience |
SR-D64244 | 532981 | Support added for recording with sIngle-option radio button inside a repeating grid | Recording a test case was not working when a single option radio button (i.e., radio button control with property of type boolean) was configured inside a repeating grid. In this case, it was found that the Radio button markup did not have a data-test-id attribute for non-template single option; this has been added. | User Experience |
SR-D64667 | 531805 | Cursor issue resolved for tab within expandable row | When pressing the “Tab” key on an expanded row, the cursor was not moving inside the expanded part. This has been fixed by adding a check to get the correct first focusable element. | User Experience |
SR-D64945 | 534322 | Accessibility enhanced for multiselect | Aria attributes for multiselect items and container have been added to enhance accessibility. | User Experience |
SR-D65034 | 529564 | Check added for malformed query on F5 refresh | A 500 Internal Server Error occurred when F5 was clicked to refresh the screen. This was traced to a malformed URL that was missing the '?' before the query parameters, and has been resolved by adding a check in the pzpega_ui_dynamicContainer_lite js file replaceHistory method that will insert the question mark if it is not present. | User Experience |
SR-D67012 | 537307 | Invalid dropdown time will retain entered time | If a datetime control using dropdown mode and a timeofday property had a validation error, on refresh the current time was being set in the dropdown. This occurred when selecting only one part of the time property (only minutes or only hours), and included an error indicating that the provided time was not a valid time of day value. To resolve this, an update has been made so that if this combination has a validation error, on refresh setting the user-entered time will be given in the dropdown instead of the current time. | User Experience |
SR-D68311 | 535985 | Corrected table row highlighting on iPad | A table row was highlighted when clicked on an iPad in landscape view, but when the device was rotated to portrait view the row was not highlighted. This was traced to the background CSS overriding the selected style, and has been corrected by modifying py-responsive-overrides.css. | User Experience |
SR-D68776 | 535466 | Improved Timezone sync between operator setting and server | When the operator timezone was empty, it defaulted to America/New_York in client side code. To better sync client and server, changes have been made so that when an empty timezone is seen, the system will retrieve the timezone from the server configuration. | User Experience |
SR-D71355 | 537007 | Support added for dynamic CSS class reference in optimized grid | When using the property pyStatusWork in an optimized grid, it was not possible to set a color code for different work statuses. This worked on an unoptimized grid. This has been resolved with the introduction of a dynamic CSS feature. This control can be changed to an autogenerated control like "Formatted text" and apply color coding through classes. To use this, a property value must be specified in cell classes in the presentation tab of the table cell, and then populate each result of a data page with that property which contains some class value appropriate for status value. CSS must be written for the different classes (class name is stamped on <td> in markup). | User Experience |
SR-D71522 | 539322 | Radio button error resolved for scenario testing | When creating a scenario test case that selected a radio button and navigated the screen, it worked to complete a case and save the scenario test case in a rule set. However, attempting to then run the scenario test case stopped with the error message "Value cannot be blank" for the radio button even though the value "No" was captured for the button. This was traced to the firing of the change event, and the system has been updated so 'pega.u.d.setProperty' will only fire a click event on a selected radio button option. | User Experience |
SR-D73260 | 536889 | Multiselect control support for offline-enabled iOS app | After a custom mobile application for iOS was built and was running on iPad for an offline-enabled user adding a multiselect control into a section as part a flow caused the screen to hang when a save or submit was performed. This has been resolved by enhancing support for offline multiselect submit with the addition of pzpega_ui_template_multiselect_capsule to offline static bundle. | User Experience |
SR-D74057 | 540059 | Updated aria handling for Dynamic Layout Group 'Accordion' | The Dynamic Layout Group display type 'Accordion' was not getting initialized properly on the browser developer inspector. This was traced to the aria-selected attribute set to always be true, and has been resolved by adding logic to set and unset aria- selected only on the active tab. When the tab is not active, then aria-selected will be false. | User Experience |
SR-D76952 | 542076 | Popovers properly attached to elements while scrolling | Account overlay popups were fixed to the screen, causing the popover to not be attached to its associated element while scrolling. This has been resolved with the addition of the needed scroll handlers. | User Experience |
SR-D80149 | 545604 | Correct very large decimal number rounding error | Rounding errors were seen in a text input field for decimal property configured to round to 2 decimal places and format with comma group separators if more than 15 digits were entered. The first time the focus moved out of the field, the rounding was correct. After clicking save, which performed a reloadSection with activity SaveAndContinue (form save), the value was rounded incorrectly. This was an issue with the ability of javascript to handle large decimal numbers as type number, and has been resolved by changing the handling to be of type string. | User Experience |
SR-D80798 | 545241 | Updated attachment popover handling for IE | After configuring a button consisting of two events, 1. On click --> View Attachment and 2. Hover --> Show Smart info, an attachment popup opened whenever the button was clicked, and moving the cursor out minimized the attachment. To resolve this, dismiss callback logic has been added in popover close for use with IE. | User Experience |
SR-D81341 | 546006 | Scroll bar scrolls to element automatically with Set Focus | An issue with the Scroll bar not scrolling automatically to the correct element when using Set Focus has been resolved by including element select logic in settimeout. | User Experience |
SR-D86937 | 546935 | Cross-site scripting protection added to ClientDynamicData | Cross-site scripting protection has been added to the "DesignViewIframe" & "pzHarnessID" parameters in the pzClientDynamicData HTML rule. | User Experience |
