Starting on March 6, 2023, Pega will offer Pega Mobile Client™ version 10.0.0.
Affected versions
Pega Mobile Client 10.0.0.
Impact
To highlight the fact that Pega Mobile Client is platform-independent and backward-compatible, Pega is changing the versioning pattern for Pega Mobile Client.
Pega Mobile Client 10.0.0 is compatible with both Pega Infinity™ and Pega Launchpad™. See Mobile support matrix.
Using the latest version of Pega Mobile Client is the best practice, as documented in Updating mobile apps.
Suggested Approach
If you force a build using ‘Other’ channel (Pega Platform version 8.2 or later versions), you will not get the latest version of Pega Mobile Client and its benefits.
In Mobile Configuration, the Advanced tab, for the option Stop using ‘Other’ building channel, use the default channel.
