Issue
User imports a Blueprint that contains Unicode characters. However, the import process fails with an error.
Error
This Blueprint file contains unicode rule descriptions and unicode input is not enabled on this system. Please consult your system administrator.
Steps to reproduce
- Create a Blueprint that contains Unicode characters. For example, German sharp S
- Import the Blueprint into Pega Platform.
Solution
Enable the EnableUnicodeRuleNames Dynamic System Setting.
For more information, refer Enabling Unicode character support for object names.
"EnableUnicodeRuleNames" dynamic system setting (DSS) in Dev Studio determines whether a user can name objects by using Unicode characters. An administrator must configure this setting as part of the system setup. The default value for the DSS is false. If the value is false and a user enters characters that require Unicode support, the system displays an error message.
https://docs.pega.com/bundle/platform/page/platform/app-dev/enabling-un…
