Symptom
Explanation
Solution
Related content
Symptom
On a few occasions when supporting a client, Pega engineers tried to perform a TRUNCATE action on the database table pr_sys_locks. DefragSysLocksDaemon was running on Stream nodes. This blocked the Pega database and caused the Pega application to stop working.
Explanation
A DSS for the class syslocks was set to run the defragment operation on the pr_sys_locks table every hour of the day (every 60 minutes).
When the defragmentation operation is running, if any UPDATE or CREATE operation is performed during defragmentation, you can expect operations on the Pega database to be blocked.
Solution
Update the DSS for the class syslocks to specify the following values:
Dynamic System Setting |
Suggested Values to Resolve This Problem Scenario |
syslocks/defragIntervalInHours |
24 |
syslocks/defragHourOfDay |
1 |
syslocks/defragIntervalType |
DAILY |
syslocks/defragEnabled |
true |
Related content
Product Documentation
Developer Knowledge Share
