WS-Security Service SOAP
Trying to enable WS-Security in Rule-Service-SOAP and testing via SOAPUI, not sure what is the issue here
Passing the below header via SOAP UI in the soap envelope
<soapenv:Header>
<wsse:Security xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">
<wsse:UsernameToken wsu:Id="UsernameToken-676D7DF24681512F9E16316474247873">
<wsse:Username>user</wsse:Username>
<wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordText">password</wsse:Password>
</wsse:UsernameToken>
</wsse:Security>
</soapenv:Header>
<soapenv:Header>
</wsse:Security>
</soapenv:Header>
error message i am seeing
<soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:soapenc="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<soap:Fault>
<soap:Code>
<soap:Value>wsse:FailedAuthentication</soap:Value>
</soap:Code>
<soap:Reason>
<soap:Text xml:lang="en-US">javax.xml.soap.SOAPException: InputStream does not represent a valid SOAP 1.2 Message</soap:Text>
</soap:Reason>
</soap:Fault>
</soap:Body>
</soap:Envelope>
Anything specific pega is looking for SOAP 1.2 version ?
