CYBG
Last activity: 4 Sep 2017 4:42 EDT
What versions of IBM MQ does 7.2.2 support?
We currently have most of our applications running on 7.1.8. We're looking to start using 7.2.2. However, there has been some debate among our infrastructure team as to whether 7.2.2. can work with older versions of IBM MQ. I can't see anything in the platform support or update guides about MQ versions. Can anyone shed any light on this, please?
I now have the information, courtesy of Terry Layman at Pega:
"My thought is that someone has read this PDN article:
https://community.pega.com/ibm-mq-server-support-secure-message-queuing/ibm-mq-server-support-secure-message-queuing#comments
and read into the article something which was not meant.
Namely, where the article says: "For Pega 7.2.2, use the IBM MQ V9.0 client libraries..", it is ambiguous as to meaning.
The information which I have received from Engineering is that this is NOT meant to say that one can ONLY use MQ V9.0.
Instead, the version of the MQ client libraries installed in the Pega classpath determines the version compatibility with the MQ server. The PDN article recommends V9.0 of the client libraries because that will be backwards-compatible with all versions of WebSphere MQ from 9.0 down.
So you can use the same MQ 8.x libraries as now with 7.2.2 to communicate with an MQ 8 server.
The other information is If you are running Pega in a WAS container, there’s nothing to install. If you are running Pega in a different app server, you need to download and install the appropriate MQ client JARs."
