What values are required in the fields for prpcServiceUtils.properties file
| Property name | Value |
pega.rest.server.url |
The URL for the REST service, specified in the following format:
http://myhost:8080/prweb/PRRestService |
pega.rest.username |
The operator name on the target system with access to REST services. |
pega.rest.password |
The password of the specified operator. |
pega.rest.proxy.host |
The host name of the REST proxy server. Do not use localhost as the host name. |
pega.rest.proxy.port |
The port for the REST proxy server. |
pega.rest.proxy.username |
The operator name on the REST proxy server with import and export access. |
pega.rest.proxy.password |
The password of the REST proxy operator. |
pega.rest.proxy.domain |
The domain of the REST proxy server. |
pega.rest.proxy.workstation |
The workstation ID for the REST proxy server. |
pega.rest.response.type |
The REST response type, either xml or json. The default value is json. Rollback, restore point, and update access group operations support only json. |
user.temp.dir |
Enter the full path to the temporary directory. Leave this blank to use the default temporary directory. |
