TATA CONSULTANCY SERVICES
Last activity: 27 Jul 2015 20:01 EDT
What is the Significance of "Engine Threads" in the PegaCALL CTI Link ?
Hi PegaCALL SME's,
1) What is the Significance of "Engine Threads" section which is present under the Advanced TAB while configuring the PegaCALL CTI Links ?
2) What does Minimum Threads mean and what is the minimum value that can be set ?
3) What does Maximum Threads mean and what is the maximum value that can be set?
4) What does Users per Thread mean ? Does it directly correlated to the number of CSR's those will be connected to that Particular CTI Link Engine ?
5) In which all scenarios does the CTI Link Engine Threads get created ?
Hari
This is for configuring the Java threads used to process CTI events. Min and max are the absolute min and max (for a single engine/JVM). The thread pool will grow within the configured min and max as users (CSRs) login to CTI, based on the users-per-thread configured. Note that these are a pooled resource, so you do not need a thread per user, for example.
