United health group
Last activity: 10 Mar 2016 5:49 EST
What is diiference between Assocoation and class Join in RD
What is diiference between using Assocoation and class Join in Report defition
Pegasystems
Hope below PDN urls give you detailed info:
https://docs-previous.pega.com/when-and-how-create-association-rule-support-reporting
Pegasystems
Associations refer to Rule-Obj-Association instances which are pre-defined join conditions that the developer can use in multiple reports. Class joins are specific joins that the report would need just for that report (and not reused elsewhere).
Also, Associations are available in the report editor but class joins are not.
United health group
What is report editor ? Do U mean in manager portal when the reports the opened?
Pegasystems
Simple explanation - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
What you can do in report editor - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
Even more details - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
The manager portal provides access to reports via the report browser - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm. When an report is created from the report browser, it opens the report editor. When you run an existing report (either from the report browser or run button of the report definition ruleform), it opens the report viewer - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm. From the viewer, you can edit a report and it will take you to the report editor where you can modify the report - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm.
United health group
what is simulated data option in Reports?
Pegasystems
In the URL - https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm, the following detail is given
Actual Data / Simulated Data |
Click to use either actual data or simulated data in the Report Editor. Designing a report with simulated data is useful when working in a development environment with limited data. It is also useful when a report query is very expensive and you do not want to re-retrieve the data for display each time a change is made in the Report Editor. This will make editing faster. |
Based on the properties that you are trying to retrieve, the report editor will show dummy data based on the property type without actually running the query and getting the data from the database. As the explanation above mentions, this is useful when the query takes too long to execute or returns too many results. Every change to the report in the editor will trigger a run of the query (modified with the changes made) to show actual data if that option is chosen.
United health group
Hi Rajiv,, I read this but it was not clear as they didn't mention where this dummy data comes from so could u please explain
Pegasystems
The dummy data is generated through the code. It is not stored anywhere in the database as we don't execute SQL when simulated data option is chosen.
United health group
Through code means is it cached data or something?
Pegasystems
No, it is generated values based on property types through java code.
United health group
ok Thank you
