Avensys Consulting Pte Ltd
SG
Last activity: 23 Nov 2020 3:46 EST
Warning Message: HTTP response code 301
I created a REST API using the REST connector (Connect-REST) in PEGA.
When I run the REST API, the following warning message was displayed:
"The HTTP response code of 301 indicated a server redirection. Redirection is not supported for Connectors using the PUT method. // The body of the service's response, which is set up for mapping in the Connector rule, was empty for this service call."
Please kindly advise on how I can resolve this issue.
Thank you.
