Validation on change grid input
Hi all,
In the class of a data type, I have an activity (method: Obj-Validate) which carries out a validation (validation rule in this data type class as well).
This activity is referenced in an action set (event: Change, action: Run Activity) of a grid in a section in another work class. However, an error message with the validation message (“Correct X”) appears (“Errors: InputProperty: **Correct X”), when the input property InputProperty of the grid is validated for incorrect input.
By the way, I tried validation differently, by creating a similar validation rule and an activity in the other work class (of the section including the grid). However, by referencing this alternative activity in a Refresh-This section action, the validation works fine, but this is not preferred (as the whole section refreshes on change of a single input).
Alright friends..
Looking forward to any suggestion for a fix.
Ryan
