Using pzGetDataPageJSON, JavaScript API pega.api.ui.actions.getDataPage()
Referring to: https://support.pega.com/support-doc/pega-security-advisory-d22-e22-f22-vulnerabilities-%E2%80%93-hotfix-matrix
It is mentioned that usage of pzGetDataPageJSON or JavaScript API pega.api.ui.actions.getDataPage() will leads to Cross-site scripting (XSS) is an attack.
Can someone from community helps to understand whether this is used in in the Product?
If not, what is the use case to use this?
How to use this?
How to check the issue before and after the change?
***Edited by Moderator Marije to remove INC-247736 Support Case Details ***
