Cognizant
BE
Last activity: 11 May 2017 3:22 EDT
Using "mode=literal" can expose the system to cross site scripting attacks - use with caution.
i have imported XSD in pega 7.2.2 version for one of our requirement through Connector and Metadata wizard.
System automatically created parse rules and XML stream rules. For all the XML stream rules we have got severe warnings "Using "mode=literal" can expose the system to cross site scripting attacks - use with caution."
when i check mapping i did not see any mode mentioned as literal all the modes mentioned as standard. but when i check XML source mode mentioned as "literal".
Pega 7.2.2:
<pega:r n=".CompanyName" m="literal"/>
In 6.3 if mapping mode is "Standard" in the XML source mode mapped as "normal".
<ns1:Notes><pega:reference name=".Notes" mode="normal"/>
I can see a difference in automated generate XML.is this some product issue in pega 7.2.2.
we have justified warning in development environemt. will it causes any security issues in production level.
Thanks.
Hi Praveen,
Adding to the Shantini explanation the change from mode=literal to normal in XML stream for v7.2.2 is delivered via. HotFix-33128 and you can raise an SR with GCS team for this change.
Right now the status of this HotFix is delivered to end user and not yet confirmed by the end user.
Hope this information might be helpful to you.
Regards
Mahesh
