Using display time period in report's filters with custom section
I found ootb section pyGridFilterRangeFields (Pega-ColumnFilterCriteria) that contains a drop-down to display time periods like current quarter or previous quarter. I tried to use that section in the report's filters with custom section:
If I try to use the property in the report filters I get an error since the property used in the section is of type Text, and I try to compare it with a DateTime one... However if you use the display time period in the default report filters it works good:
I found this post from some time ago, but I think is inconclusive if this can be accomplished using filters with custom section.
Thanks for any thoughts on this,
-Jose
