Independent
Last activity: 2 Dec 2019 8:55 EST
Using Attachments in Connect REST - other than Base64 Encoded string
According to help pages, in order to send an outbound message with attachments via Connect-REST, the binary data has to be encoded as a Base64 string.
Now in version 7.4 and above, with Repository API, the D_pxNewFile datapage will by default use Inputstream as opposed to Base64 encoded string. However, if the Custom Repository in turn calls a Connect REST rule that uses attachments, does it mean the Inputstream has to be encoded to Base64 still? Is there any other properties on the pyRequestAttachmentPage that support Inputstream instead?
