Lloyds Banking Group PLC
Last activity: 9 Dec 2019 7:22 EST
Use pyDecimalPrecision on String properties
v7.3.1
I created a post (referenced below) to understand behavior of String properties when values are set from a Double property
https://collaborate.pega.com/question/behavior-string-property-value-set-double-property
Following up on this -
I've been looking at options to remove the decimal point added to the string value even though the original double value doesn't have any decimal point and one of the options I thought I could use was to set the pyDecimalPrecision property qualifier on the String property and set precision to 0.
While I understand that it makes sense to use this qualifier against properties of decimal type only, the usage on that qualifier rule indicates that it can be used for STRING/DECIMAL types but it doesn't work on STRING types i.e can't add this qualifier and set precision to 0 as system throws error that the qualifier cannot be used for string properties.
Can someone please confirm that the qualifier shouldn't work for STRING types or if this is a product bug and the qualifier rule usage is correct?
Usage on the rule for quick reference:
Add this qualifer to a STRING/DECIMAL property to provide a specific number of dicimal digits of precision at which its value should be clamped. This qualifier is ignored on any other type property.
