Ford Motor Company
Upgrade fails from 6.2 sp2 to 7.2
We are upgrading our application from Pega 6.2sp2 into Pega 7.2, after we successfuly splited the schema tabls(Rules and Data). While running the upgrade.bat getting the below error,
[java] 2016-08-09 13:47:01,825 [ main] [ ] [ ] (l.access.MigrateSQLChangeProxy) INFO - Migrated 0 instances of Data-Admin-Product
[java] Aug 09, 2016 1:47:02 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.database.DatabaseException: Database-General Invalid object name 'Rules.XXXX'. 208 S0002 Invalid object name 'Rules.XXX'.
[java] DatabaseException caused by prior exception: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Rules.XXX'.
[java] | SQL Code: 208 | SQL State: S0002
[java]
[java] From: (unknown)
[java] Caused by SQL Problems.
[java] Problem #1, SQLState S0002, Error code 208: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Rules.XXX'.
[java] at com.pega.pegarules.deploy.internal.archive.importer.ImporterDataModelImpl.getCountOfClassInTable(ImporterDataModelImpl.java:432)
[java] at com.pega.pegarules.deploy.internal.archive.importer.TableMigratorImpl.determineAndMigrateChanges(TableMigratorImpl.java:57)
[java] at com.pega.pegarules.deploy.internal.archive.importer.UpgradeBaseArchiveImporter.beforeLoad(UpgradeBaseArchiveImporter.java:72)
[java] at com.pega.pegarules.deploy.internal.archive.importer.ArchiveImporterAbstract.importArchive(ArchiveImporterAbstract.java:38)
[java] at com.pega.pegarules.deploy.internal.archive.importer.Upgrader.handleArchive(Upgrader.java:150)
[java] at com.pega.pegarules.deploy.internal.archive.importer.AppBundleHandler.deploy(AppBundleHandler.java:90)
[java] at com.pega.pegarules.deploy.internal.archive.importer.Upgrader.runUpgrade(Upgrader.java:57)
[java] at com.pega.pegarules.deploy.external.util.UpgradeUtil.main(UpgradeUtil.java:73)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
[java] at java.lang.reflect.Method.invoke(Unknown Source)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Rules.XXXX.
[java] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:197)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1493)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:390)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:340)
[java] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:4575)
[java] at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1400)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:179)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:154)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:283)
[java] at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.executeQuery(DatabasePreparedStatementImpl.java:411)
[java] at com.pega.pegarules.deploy.internal.archive.importer.ImporterDataModelImpl.getCountOfClassInTable(ImporterDataModelImpl.java:428)
[java] ... 16 more
[java]
[java] Aug 09, 2016 1:47:02 PM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] com.pega.pegarules.pub.database.DatabaseException: Database-General Invalid object name 'Rules.XXX'. 208 S0002 Invalid object name 'Rules.XXK'.
[java]
[java] Problem #1, SQLState S0002, Error code 208: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Rules.XXXX'.
[java] 2016-08-09 13:47:01,872 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 1 for database "pegarules" to the pool as it previously encountered the following error
[java] User ID: (unknown)
[java] Last SQL: select count(*) as "count" from Rules.XXX where pxObjClass = 'XXXX'
[java] com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Rules.XXXX'.
Did anyone faced this issue and how its been resolved?
