Upgrade 7.3 to 8.4.1 - Initializing service registry in embedded environment since the persistence classes exist
I am upgrading 7.3 system to 8.4.1. At one stage Upgrade has stuck since last 7 hours and below is the entry in the log. I beleive it is not an error but not sure why it is stuck. Any help would be highlyt appreciated.
[java] 2020-09-03 09:43:06,749 [000197237.ic.ing.net] [ STANDARD] [ ] [ ] (able.internal.VirtualTableImpl) INFO - ...Finished. Preloaded 13.9MB for 59617 rules in 11542 ms [java] 2020-09-03 09:43:06,749 [000197237.ic.ing.net] [ STANDARD] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Virtual Table initialization completed in 11558 ms [java] 2020-09-03 09:43:06,759 [000197237.ic.ing.net] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - Awaiting for StartupTasks (parallel cache loading to finish)... [java] 2020-09-03 09:43:06,763 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - Initializing service registry... [java] 2020-09-03 09:43:06,763 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - Initializing service registry in embedded environment since the persistence classes exist [java] 2020-09-03 09:43:07,910 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] (al.access.PerformanceProcessor) ERROR - Unable to apply pre processing for performance optimization [java] 2020-09-03 09:43:08,881 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] (al.access.PerformanceProcessor) ERROR - Unable to apply post processing for performance optimization [java] 2020-09-03 09:43:10,523 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] (al.access.PerformanceProcessor) ERROR - Unable to apply pre processing for performance optimization [java] 2020-09-03 09:43:11,524 [_IN_SERVICE_REGISTRY] [ STANDARD] [ ] [ ] (al.access.PerformanceProcessor) ERROR - Unable to apply post processing for performance optimization
