TCS
TCS
SE
TCS
Posted: Jan 29, 2020
Last activity: Feb 11, 2020
Last activity: 11 Feb 2020 8:12 EST
Unsupported protocol: rest while configuring SMA
Below error is obtained when configuring SMA on Pega 7.3.1 on WAS 8.5. Is there any additional configuration required to get this working?
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892) Caused by: javax.management.MBeanException: Exception getting MBean Server connection. Fail to instantiate WASJMXConnector Failed to get mbean server connection Cannot connect to the server with specified settings Unsupported protocol: rest at com.pega.jmx.connection.managenodes.Node.getMBeanServerConnection(Node.java:419) at com.pega.jmx.ui.action.AuthenticateAction.execute(AuthenticateAction.java:164) ... 97 more Caused by: java.lang.Exception: Fail to instantiate WASJMXConnector Failed to get mbean server connection Cannot connect to the server with specified settings Unsupported protocol: rest at com.pega.jmx.connection.managenodes.WASJMXRemoteConnection.acquireConnection(WASJMXRemoteConnection.java:51) at com.pega.jmx.connection.managenodes.Node.getJMXConnector(Node.java:403) at com.pega.jmx.connection.managenodes.Node.getMBeanServerConnection(Node.java:413) ... 98 more
********* Service URL ******* service:jmx:rest://pegaXXX:8880/IBMJMXConnectorREST
