Unexpected error message: Lucene Syntax search queries are not supported when property level security is enabled
currently we face the error message Lucene Syntax search queries are not supported when property level security is enabled in our logs which originates from pySearch activity (step 2; a Java step).
I checked all the properties on the corresponding class and non of them had any type of property security (i.e. access when). Same for any type of property security rules.
What could be the root cause of this issue?
Is it possible to modify logs so that the output is more specific (i.e. which property security is meant here? etc.)?
Many thanks in advance.
Edit: After rechecking I found out that we have some access control policies and conditions in place for the corresponding class, however it used to work fine in the past.
***Edited by Moderator Marije to add BUG tag***
