Unable to update check box value in eform
My requirement is to populate a pdf template with user input values. In order to achieve this I'm using eForm rule to map the Pega property. While mapping able to map text value but check box control on editable form unable to set the value.
Pega property value set as "true" for check box property.
Is any other way to map this check box?
