Unable to run update wizard for REST with JSON connector
There does not appear to be any support for running a wizard update for a REST connector defined with JSON at least as of 7.2. Is there support for it in a higher version? Is this on the roadmap as an enhancement?
Update does work as long as everything is entered the identically as the first run. However another connector with the same name will be generated and appended with a number. (ex. ConnectorName1)
