Unable to get data from Windows app grid
I'm trying to automate a windows app application, unfortunately, I can't get the data from the grid table of the application. See screenshot attached. Can you help me on what is the best approach to get the data dynamically as the number of records is not constant per search, as you can see from the screenshot, there's a scroll bar on the right depending on the number of records found.
If possible, can you provide as an approach without using .Net code?
***Edited by Moderator Marissa to close comments***
