TATA Consultancy Services
Posted: Sep 13, 2017
Last activity: Sep 13, 2017
Unable to generate the library for ExcelIntegration • DCOdocumentToBytes function.
Unable to generate the library for ExcelIntegration OOTB rule in PRPC 7.3 version.
Error:
Error(s) detected while generating java. Compiler reported: ---------- 1. ERROR in /com/pegarules/generated/DCOdocumentToBytes_071031_Hx2A3G6yuKw_sgQnDHLlPQ.java (at line 99) tf.setAttribute(javax.xml.XMLConstants.ACCESS_EXTERNAL_DTD, ""); ^^^^^^^^^^^^^^^^^^^ ACCESS_EXTERNAL_DTD cannot be resolved or is not a field ---------- 2. ERROR in /com/pegarules/generated/DCOdocumentToBytes_071031_Hx2A3G6yuKw_sgQnDHLlPQ.java (at line 100) tf.setAttribute(javax.xml.XMLConstants.ACCESS_EXTERNAL_STYLESHEET, ""); ^^^^^^^^^^^^^^^^^^^^^^^^^^ ACCESS_EXTERNAL_STYLESHEET cannot be resolved or is not a field ---------- 2 problems (2 errors) Compile failed.
Muthu
