Capgemini
SE
Last activity: 20 Mar 2017 6:21 EDT
Unable to create new application in 7.2
I am unable to create new application on Pega 7.2.I am getting below error:
Error
Error
and when I click on hyperlink
Error
Can you please share complete PegaRULES logs when you try creating application?
Capgemini
SE
Attaching the log files for the same .
Strange error messages I can see in the log
- A commit cannot be performed because a deferred delete of an instance of class @baseclass failed.
- The deferred delete failed with the following exception
- Not returning connection 1 for database "pegarules" to the pool as it previously encountered the following error
- XML of page with error: <?xml version="1.0"?
for more info please find the attached logs
Can you please see if private synonyms is present for pwbv4_rule_locking for the database user that is running PRPC
Capgemini
SE
Hi Arvind,
Which database I need to check for the synonym?Can I check it via Application or needs to be verified from Database level?
I believe, you are using Oracle as your database, kindly confirm.
You can involve DBA who can do this for you ( checking private synonyms)
Capgemini
SE
Yes Arvind.. we are using oracle database. we have upgraded the system from 7.1.9 to 7.2.
As per our DBA:The migration and update steps were all successful as per the logs.
synyonym exsist as an Oracle view in the old RULES schema "Rules". However, this does not exist in the new RULES schema "Rules72".
Capgemini
SE
Could you please guide what the next step should be?
Create a private synonym for PegaSchema.pwbv4_rule_locking for the database user that is running PRPC.
Capgemini
SE
Thanks Arvind it is working now. We deployed PegaSchema.pwbv4_rule_locking as view in database
Sopra Steria
FR
I am facing the same problem with a postgres db installation (PRPC 7.2),
could you give any guidance on the local change to do to be able to create a new application?
(error is also on pwbv4_rule_locking)
best Regards,
Vikesh NAPAL.
This comment has been branched out as a new node and the new thread can be followed here
You have replied to an older thread which lacks activity. To gather better visibility for your question, I have branched it to create a new question. You may continue your conversation on this thread: https://collaborate.pega.com/question/problem-postgres-db-installation-prpc-72
Hope the information is helpful.
Thanks!
