TCS
Last activity: 22 Oct 2020 9:15 EDT
UI not rendering after restart
After deployment to QA, UI is not rendered properly even after several restarts. We even tried reverting the deployed code and then restarted. But still the issue persists with the following error in Log.
Problem appending stream null com.pega.pegarules.pub.PRRuntimeException: Unhandled exception executing JSP: Unhandled exception executing JSP: Unhandled exception executing JSP: Unhandled exception executing JSP: The page or property CAPortal.caItemsToReview(1).pxObjClass is unmodifiable. Calling method: com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.setValue(Object) Details: property is reserved at com.pegarules.generated.html_harness.ra_stream_cpmrightframeharness_noinput_ca745f736bb21539667487f143a1afbe.execute(ra_stream_cpmrightframeharness_noinput_ca745f736bb21539667487f143a1afbe.java:290) at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:654) at com.pega.pegarules.jsptags.IncludeTag.getStream(IncludeTag.java:358)at com.pega.pegarules.jsptags.IncludeTag.getNonJSPStream(IncludeTag.java:284)
