Is there any way to get property's label automatically for Grid column header
When I create a repeating grid using Report Definition, if I check "Create grid dynamically", then system gets the label by itself for each column in the grid. However if I don't use "Create grid dynamically" and add field by myself, I always need to specify a Value. I understand this is a great advantage if you want to change the label from out-of-the-box ones, but most of the times I use the default. So naturally I want to just use the default label for these fields because otherwise many developers will use slightly different Value in other places and system will become inconsistent. I want to avoid that.
