Stratosphere Technical Consulting
Last activity: 30 Aug 2017 0:20 EDT
Testing a strategy in the Marketing Portal with a data transform
When logged in to the Marketing Portal as a Strategy Designer, if I wanted to test a strategy using a data transform, is it possible to set values just for testing.
Using the test run panel, when trying it, it seems that you can select a data transform to test but you cannot even view the values in there nevertheless modify them
