Celfocus - Soluções Informáticas Para Telecomunicações SA
PT
Last activity: 31 Oct 2019 15:03 EDT
Test Run Batch using a Data Flow
I've tested a strategy running a test run batch using a data flow and I have some question about the result values.
have two filters with 90% for each one but the sum of the % of the two fitlers shouldn't be 100%(Filter.png) ?
In the end of the strategy the last component (a set property) have 100% but in the result component have 99%(Result.png) .
Please see the images attached.
Anyone can you help me to understand these values?
Thank you.
