Last activity: 2 May 2016 11:35 EDT
System-User-Achievement error in log - unrecognized class and purpose. Does anyone know what this could be?
We just recently started seeing the below error in our logs and don't recognize it. We are on Pega7 7.2GA with multi-node clusters and High Availability enabled.
It appears like a user may have triggered some feature which resulted in the agent processing to kick off and try to save/update the instance in the System-User-Achievement class, but fails. It is not something enabled in our Rule-Access-Role-Obj and Rule-Access-Role-Name instances.
13 Apr 2016 21:16:05,239 [ PegaRULES-Batch-5] (internal.access.Saver) ERROR userIDShownHere - You are not authorized to save instance SYSTEM-USER-ACHIEVEMENT USERIDSHOWNHERE!MOBILE-APP-BUILD, of class System-User-Achievement
1. What is the System-User-Achievement class and its purpose/intent?
2. How and where would it be used (User portal, developer portal, reporting, etc)?
3. Security, Roles, Privileges involved in granting access to the User and Batch Agents?
4. Landing Page for configuration or portal?
5. Enabling and Disabling this feature (can it be disabled, should it be)?
Thanks! - Steve
