@String.whatComesBeforeFirst() not working
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
Hi
As per the usage of @whatComesBeforeFirst(String,char), it takes String and character as arguments but you are passing string "I-" which is not vailid as per the usage.
Below is the usage
Usage:
Returns the portion of string1 that comes before the first occurrence of the specified character.
If that character is not in the string, returns whole string.
input source string, token character to locate
return sub-string that appears before token.
Hi
I am facing the same issue.
Could you please help us with the correct format?
Jashwanth
What are you trying to do and what is the error you see?
You can see a sample for the format on the following link.
