SSA Mission - Multivariate Circumstancing Knowledge Check
In the SSA Mission - Circumstancing module - Multiple Variable Rule Circumstancing Topic:
-The last knowledge check section has the following question: If a rule is executed with the condition 'Dept=Engineering' which rules would be selected? The answer is a rule rule where the base version is in a higher RuleSet than the rule that is circumstanced for 'Dept=Engineering'...
but based on the Rule Resolution module, the circumstanced version is priority over RS version if the Applies to and Ruleset are the same....and this would allow for base rule updates to not force ALL circumstanced rules to update as well....
Am I missing something? or is knowledge check question incorrect?
