Societe Generale
Last activity: 28 Mar 2017 9:47 EDT
SQL Function Alias - Not working
Hi Team,
I have a requirement of subtracting X minutes from the current datetime and use it as a criteria in RD. I have created a function alias for this like below.
sysdate + interval '{1}' minute
RD works correctly if i hardcode like sysdate + interval '-60' minute. If i replace the -60 with a parameter value i get below error while runing report definition.
** An error occured on executing the query for the report definition - There was a problem getting a list: code: 17003 SQLState: 99999 Message: Invalid column index
DatabaseException caused by prior exception: java.sql.SQLException: Invalid column index
| SQL Code: 17003 | SQL State: 99999
Please find the attached screen shot of the function alias rule.
***Moderator Edit: Vidyaranjan| Updated Categories***
