Specific requestor timeout
we have a situation where a special user is used to check application status by a 3d supervision application, that runs frequently.
This user is used to snapstart an activity, which has "may start?" checked but not "Authenticate?".
We need that the system will not have a lot of requestors for supervision. For that I see 2 options:
1- (preferred) reuse the same requestor whenever the activity is called. Perhaps there is a system setting or a prameter to pass in the snapstart but I can not figure it out.
2- set a short timeout for these requestors without afecting final user requestor timeout. The authentication timeout from access group does not apply while we do not use authentication. The passivation timeout applies to all users.
Have you an Idea how this can be done ?
Thank you for your help.
