Space after reference rendered in HTML not fixed by pxDisplayText
I am having an issue with my correspondence rules when I include a property reference and the HTML is rendered, a non-breaking spaces gets added immediatly after the property value. This is an issue in salutations on correspondence emails. I have even verified in the clipboard that the .ContactName value does not have a trailing space.
I see that this has been an issue in the past according to the following support link which tell me to use a format attribute of "pxDisplayText".
I want the output to be:
John Doe,<br />but the pega correspondence code of:
<pega:reference name=".ContactName" format="pxDisplayText"></pega:reference>,<br />is rendering as:
John Doe ,<br />I know I can do something like create a data transform just before the email is sent and build the value I need and send that value into the correspondence, but that seems to be a lot of overhead for what should be according to the support link a pretty straight forward fix/resolution.
We are using PegaCloud 8.3.2.
Before I open a service request ticket with Pega support, I wanted to check with the community to see if anyone else has had this issue with pxDisplayText not working as expected and if they have come up with a solution.
Thank you!
