Some elements in the JSON DT are not getting mapped based on the step order
Hi Guys,
We have an issue with JSON DTs which we are using to map the clipboard data to the REST service. Some of the elements are not getting mapped based on where (which step) they at in the JSON data transform.
For an example: if I am mapping "element X" is mapped after "element Y" then it does not map. But if I map "element X" before "element Y" it is working.
We have some complex JSON DTs which are mapping many elements to the REST services so managing with the step order is very difficult and we have to regression test whenever we have done a change to these mappings.
Has anyone encounter the same issue and found any solution to this?
