Set Property using Data Transform not working
I have below scenario.
I am using a Data Transform(DT) to update one text property from another text property in the same section on click of a button(which calls DT as an event).
I created a Page(samplepage) in Pages and Classes tab and refer the properties in Target and source in the definition tab of the DT, the value doesnt get populated.
For example -
created a page name "samplepage" which refers to class abc-xyz-work-homeloan
Now, when I use set operation I give as below
Set --> samplepage.targetproperty equals to samplepage.sourceproperty - this doesnt work
However, if I use pyWorkPage or just "." to refer properties in taget and source, it works.
Set --> pyWorkPage.targetProperty equals to pyWorkPage.sourceProperty - this works
or
Set --> .targetproperty equals to .sourceProperty - This works
Could you pleas help me find out why first scenario doesnt work?
