Security issues in Authentication Service
Our application has encountered below security issues. Is there any approach to fix these security defects?
1.StricitTransport Security not enforced.
The application fails to prevent users from connecting to it over unencrypted connections. An attacker able to modify a legitimate user's network traffic could bypass the application's use of SSL/TLS encryption, and use the application as a platform for attacks against its users. This attack is performed by rewriting HTTPS links as HTTP, so that if a targeted user follows a link to the site from an HTTP page, their browser never attempts to use an encrypted connection. The sslstrip tool automates this process
2.Cookie Scoped to parent domain
A cookie's domain attribute determines which domains can access the cookie. Browsers will automatically submit the cookie in requests to in-scope domains, and those domains will also be able to access the cookie via JavaScript. If a cookie is scoped to a parent domain, then that cookie will be accessible by the parent domain and also by any other subdomains of the parent domain. If the cookie contains sensitive data (such as a session token) then this data may be accessible by less trusted or less secure applications residing at those domains, leading to a security compromise
3.Cookie set without HTTP only attribute
If the HttpOnly attribute is set on a cookie, then the cookie's value cannot be read or set by client-side JavaScript. This measure makes certain client-side attacks, such as cross-site scripting, slightly harder to exploit by preventing them from trivially capturing the cookie's value via an injected script.
