Section Refresh not happening on change of a drop down
I have a drop down field. On select of a value/On change of this drop down, I want to refresh a section below the current section.
In the actions tab, 'On change' - I have set the value of the drop down to a property called 'L1Decision'.
Next I want to refresh a section below. (Ignore the data transform in the screen shot - I'm trying to set the same property in the data transform as well, because Pega had a defect for drop downs and set values before. The values were not getting set. So tried to set in through a data transform as well)
I can see that the refresh is not happening.
Could you please let me know where I'm going wrong ?
Rashmi
