Scenario Testing not populating the UI with data
I have created a scenario testing but while running the same the data is not getting populated on the UI. The UI fields have test id.
What could be the possible reason for this?
Also while recording the test scenarios, I was not able to even capture the action/data on a Multi-Select which also had test id.
Pega Version 8.1.4
