Scenario Testing Documentation to record screens and calculations
Would you share any documentation on capturing and defining different scenarios in “Scenario Testing” (UI based testing)? How to capture/record the declarative calculations and read-only fields?
For example: DueAmount, Surcharge and TotalDue fields are on screen. TotalDue is calculated declaratively by using declare expression (TotalDue = DueAmount + Surcharge). So, it’s been calculated and displayed read-only value on screen the moment values are entered in input amount fields. How to mention this calculation formula in Scenario Test Case?
Another scenario: DueAmount and Surcharge are entered in first screen and TotalDue is calculated in post transform and displayed read-only value in second screen.
What is configuration needed on TotalDue step in Scenario Test Case?
Pega Platform version: 8.1.2
I have gone through the below links which are useful in set up and start capturing the scenarios.
As of now, having dynamic calculations are not supported using Scenario Testing tool. We can assert the values that are rendered on the page and also assert some properties from predefined data page.
