Scalar properties are being set as Pages (Pega 7.1.6)
HI Team,
I am getting the below issue, when i search through PDN I got this hot fix : HFix-9495. PDN Link Node ID: 240811
Is this issue present in Pega7 also
In the tracer we got the below fail msg first
WrongMode pyWorkPage.TotTimeAdmit Page adoptDictionaryDefinition(ImmutablePropertyInfo, boolean, boolean) String the mode has been reset to match the property's definition.
Later it is getting failed at obj-save on the page.
Trying to save an invalid page: Trying to save an invalid page: page is not valid .TotTimeAdmit: The property SelFeature.TotTimeAdmit was of mode Page while adoptDictionaryDefinition(ImmutablePropertyInfo, boolean, boolean) was expecting String mode. Details: the mode has been reset to match the property's definition.
Our property TotTimeAdmit is Double which is a scalar property. If i stall this hot fix will this solve my problem. If yes can you please provide this Hot-Fix
Manoj
