LS Enterprises
Last activity: 6 Mar 2018 15:30 EST
Save As on rule doesn't copy the Test Cases.
I've been playing around with test cases, and I have a rather large decision table that I need to move to another class, which has a test case for each outcome. I've attempted to Save As the rule in the new class, but have found that none of the test cases are moved with it. Is there a way to do this, without having to manually go through and recreate each test case?
Follow up question: is there a way to point a test case to test a different rule once created? My idea behind this is to Save As each test case and point them at the copied decision table, but I can't seem to do this either.
