Last activity: 2 Dec 2019 9:24 EST
SAML Configuration: Not allowed to map '.pyUserIdentifier' property
Has anyone encountered a similar issue with SSO setup ?
In Authentication service, when I map Attribute(emailAddress) to ".pyUserIdentifier" its throwing below error.
Since from PEGA 8.x that not required to set.
Kranthi
what Pega version?
version 8.3.0
Kranthi
Yes, it doesn't require from PEGA- 8.1.1 and later versions. If you try to map uid with pyUserIdentifier and save, it will throw an error.
Abhishek
Areteans Technology
Any update on the resolution. How to we map the pyUserIdentifier property.How would Pega handle in v8x and above.
Check for pySAMLWebSSOAuthenticationActivity configurations.
Check for any customizations done in previous versions and reconfigure your customizations using the OOTB functions provided in 8x.
