GDPR Erase
Last activity: 28 Jan 2021 4:58 EST
SAML 2.0 Authentication Fails on Multi Node cluster
We have implemented SAML 2.0 Authentication which works fine with 1 node. the moment we go multi node (2 Nodes) it fails and returns to the Login page from where SAML authentication request was initiated.
In the logs I see lot of the below errors:
2021-01-09 11:32:07,788 [tejob-executor-18753] [ STANDARD] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - [QuiescePassivation] forcePassivateInner: passivated or destroyed requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] 2021-01-09 11:32:09,842 [ default task-134] [ ] [ ] [ ] ( mgmt.base.NodeRequestorMgt) INFO - [Quiesce] Found requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] on remote node: 97815d53-4e78-48cd-81fd-f3610ec37843 2021-01-09 11:32:10,007 [ default task-134] [ ] [ ] [ ] ( mgmt.base.NodeRequestorMgt) INFO - [QuiesceActivation] Requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] has been restored from passivated data as a result of quiesce 2021-01-09 11:32:10,363 [tejob-executor-18754] [ STANDARD] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - [QuiescePassivation] forcePassivateInner: passivated or destroyed requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] 2021-01-09 11:32:26,461 [ default task-157] [ ] [ ] [ ] ( mgmt.base.NodeRequestorMgt) INFO - [Quiesce] Found requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] on remote node: 97815d53-4e78-48cd-81fd-f3610ec37843 2021-01-09 11:32:26,595 [ default task-157] [ ] [ ] [ ] ( mgmt.base.NodeRequestorMgt) INFO - [QuiesceActivation] Requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] has been restored from passivated data as a result of quiesce 2021-01-09 11:32:26,877 [tejob-executor-18756] [ STANDARD] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - [QuiescePassivation] forcePassivateInner: passivated or destroyed requestor [HAQSRR961XETRX5ER1C2FOMA3R2TUD2ENA] 2021-01-09 11:32:50,234 [tejob-executor-18760] [ STANDARD] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - [QuiescePassivation] forcePassivateInner: passivated or destroyed requestor [HF7GNG5B6WL7U6QU03F7CKEG4XA8IEPLMA]
Can anyone help with how to stop this QuiescePassivation from happening.
