S3 Connection appears to disconnect.
We see our S3 connection disconnecting intermittently. I suspect some sort of timeout. See message below. I'm not sure if there is some kind of stale connection or if there is something we can do on the application side. We can go into the application and resume the flow and it will work. I'm not clear as to what is causing the disconnect. Is this the app or an AWS type of issue.
Let me know if there are any ideas.
2023-12-11 06:00:47,513 [ BlobWriter-0] [ ] [ ] [ ] ( aws.s3.AWSBlobWriter) ERROR - Exception occurred while uploading file (), in bucket (prod-pega-files)
java.io.IOException: Pipe not connected
at java.io.PipedInputStream.read(PipedInputStream.java:305) ~[?:?]
at java.io.PipedInputStream.read(PipedInputStream.java:377) ~[?:?]
at com.pega.platform.physicaldatalayer.internal.cloud.aws.s3.AWSBlobWriter.readAndUploadParts(AWSBlobWriter.java:172) ~[prprivcommon.jar:?]
***Edited by Moderator Marissa to add Support Case Details***
***Edited by Moderator Marije to add INC where URL was pasted***
