Accenture Solutions Pvt Ltd
Runtime Performance Issues while Running Solution Developed for Java Swing application In Pega Robotics Studio v 8.0.1080
Hi
I have developed a Project/Solution for automating java desktop based swing application 1.8V ,when am running the solution (which is working fine in v1058) in v1080,i have encountered below performance issues,
1)first of all solution is not working during runtime ,it takes a lot of time (which is not constant) in identifying & failing to perform methods (like performclick ) on come controls(javax.swing.JButton,javax & some menu items inside javax.swing.JMenuBar),some times throw particular control not matched error or else it will throw Error "CVirtualJavaBroker::InvokeReceived: Exception invoking method GetCountEx on object with id 18 " or else it will get stopped in middle
2)Solution works fine when testing with breakpoints by step Into F11
3)Sometimes the same solution works fine in other environments like DEV it is not taking lot of time in identified by the OpenSpan (the time it takes in other environments) but everyone it works only by putting breakpoints without breakpoints it is not at all working.
We have tried increasing more sleep time or delay (more than 30 mins) in WaitForcreate method & in Pause stage. Also tried recreating whole solution from scratch & applied match rules for failing controls but still no luck.
but we never faced this issues when running the same solution in v1058.
Hi
Are there any specific java swing application Translators Or UIConnectors available or Through Create Type Extension /Component Extension can we solve these issues?
We even had WebEx call with Pega Support Executive (SR-C26122) ,but the executive had asked us to share log files which we are not supposed to share because of compliance issues & policies.
So I request if anyone faced the same issue & had any resolution step ,please kindly provide some solution or advice as it is very emergency to get resolved.
Pravallika.
Hi Pravallika,
I am woring with the studio v7.1.63.
I am aslo facing same problem,
But i am using try- catch Solution to perform click( ), Well it's clicking but error remains the same!!.
pls find the Screen shot ofr the same issue
