Runtime error: pega.interop.dll file not found : PEGA runtime v2059
I just upgraded to PEGA robotics runtime v2059 by downloading RAR and RAS zips from the PEGA website.
However, since then i have been getting the File not found exception w.r.t pega.interop.dll
Checked in the installation folder and indeed that dll is missing, though its pdb file is there.
Tried reinstalling the runtime but same issue.
Can someone help if this is to do with the v2059 release or something i am not doing rite?
Exception Type: System.IO.FileNotFoundException Message: "Could not load file or assembly 'Pega.Interop, Version=10.0.0.0, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e' or one of its dependencies. The system cannot find the file specified." FileName: "Pega.Interop, Version=10.0.0.0, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e" FusionLog: "WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. " Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items TargetSite: Void .ctor(System.IServiceProvider, OpenSpan.Configuration.ConfigurationSettingsSource) HelpLink: NULL Source: "OpenSpan" HResult: -2147024894
StackTrace Information ********************************************* at OpenSpan.Configuration.ConfigManifestHelper..ctor(IServiceProvider serviceProvider, ConfigurationSettingsSource configSource) at OpenSpan.Configuration.ConfigManifestHelper.GetCommonSingleton() at OpenSpan.Configuration.ConfigurationFileSettings.LoadSettings() 2020-04-14 14:57:15,890 [ 1] ERROR - Runtime Application - Exiting Runtime due to exception loading configuration. 2020-04-14 14:57:15,890 [ 1] ERROR - Exception - Could not load file or assembly 'Pega.Interop, Version=10.0.0.0, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e' or one of its dependencies. The system cannot find the file specified., Verbose Message: General Information
